Keyboard error?
BWGrapher
Jun 19, 2007
55
Has any one had keyboard problem?
I got this problem today.
On the vertical mode, I can't touch the very bottom keys (.?123 space return).
Actually, it works wrong way.
When I touch ".?123" key, iPhone recognize it as shift key.
For "space" key, it recognize as "c", "v", or "b".
For "return" key, it works as "backspace" key.
On landscape mode, I have no problem.
The problem occurs only on the vertical mode.
I already tried to turn off & turn on and reset, but I couldn't fix this problem.
If any one knows solution for this problem, please let me know.
Otherwise, if any one has same problem, let me know, too.
Thx.
PS. Can I exchange my iPhone if I can't fix this problem?
If I can, what do I need to exchange?
Do I have to bring all stuff that comes with box?
Jeremiah
Jul 11, 2007
41
Maryland
Try restoring it, plug it into your computer, and on iTunes click restore, if that doesn't work you can exchange it if you have had it for 14 days or less, and I'm not sure what you need to bring if you do have to return it, but i would try the restore first.
Thx.
