Keyboard MAJORLY lagging?
guest4
Mar 27, 2008
182
If I type a string of words, it'll skip and then freeze for about 10-20 seconds until all the words catch up. It literally happens one every text, if not every other atleast. It's extremely annoying. I've restored and everything. My phone just in general is freezing constantly.
Anybody else in the same boat?
guest4
Mar 27, 2008
182
Which firmware are you running and on which device? Are you jailbroken? Unlocked?
3.0. First gen 4GB iPhone. Not jailbroken or unlocked. I have about 3gb of free space as well.
iphonewarrior
13,847
701
Have you tried a hard reset?
Hold-Power and home buttons, until the phone turns off and turns back on again.
See how you get on. I suffered badly with this back on 2.*.* days
Wiggo
Jul 7, 2007
103
Memphis
I had this problem on both my v1 and 3G iPhones, but not with the 3GS (expensive fix, I know).
iphonewarrior
13,847
701
If your problems persist and they wont go away... as long as your running stock firmware ( non-jailbroken ) then take it back to the Apple shop..
Try a Restore before that though obviously
psylichon
Oct 31, 2007
16,591
751
40
Philly
I'm fairly certain he's out of warranty. If a restore doesn't help, I'm not sure what to advise... perhaps try to revert to 2.2.1? :(
