Keyboard Option Bar Issue (iPhone 5)
Ledsteplin
Oct 29, 2013
4,814
985
65
Florence, AL
A while back, I noticed the option bar in iMessage and a few other places appeared silvery, rather than black. It only showed that way in a few places, including iMessage and in several apps such as the iCafe app. It would come and go. I finally did a hard reset, and that fixed it. It went back to black. So now it's started doing it again. Below is a screen shot of it. After experimenting and searching for the cause, I have found that it only occurs when Reduce Transparency is turned off. I'm not on beta, nor JB. This must have started with the update that included Reduce Transparency. Maybe some of you on beta could report it as a bug. :D
Has anyone with Reduce Transparency turned off noticed this? Here's the screen shot:
Adriano73
Jan 17, 2012
337
77
UK
I haven't had that but I've noticed a few little visual bugs here and there in iOS 7. For instance this when you go into usage without a data connection so the iPhone can't give me info on iCloud storage "ICLOUD" is offset and running into section above.
