Keyboard problems?
Billybobvi
Nov 23, 2008
Ok I have a iPhone 6s Plus with the newest version of iOS 9. Recently while typing in notes or typing in the search block on safari, some of the keys require me to double click them in order for them to be typed on the screen. Even the space bar. Has anyone else experienced this or have I changed a setting without knowing? I just typed this in the app using my iPhone with no problems. Seems to happen in notes and safari.
Thanks in advance
Billy
28,365
5,507
Try a hard reset. Press the home button and the power button at the same time and it will reboot. No data or settings will be lost.
Billybobvi
Nov 23, 2008
Thanks for the reply. Hard reset was the first thing I did and still continued.
Billybobvi
Nov 23, 2008
I did notice that when I finish typing a word and I hit the space bar and cursor will not advance and I have to hit the space bar twice to get it to move so I can type the next word. I'm I missing something here or losing my mind? It also happens with return key too.
Thanks again in advance
Billy
47seijar
Oct 6, 2012
342
126
43
Denville, NJ
If the hard reset didn't sort it, I think it may be a screen defect. You might want to inquire about a warranty replacement. I hate having to replace a phone, but that's an issue that would drive me up a tree in very short order.
Billybobvi
Nov 23, 2008
Figured it out. I have a Zagg screen protector and an OtterBox case. After taking off the OtterBox the keyboard worked fine. It must have been slight pressure on the screen by the OtterBox that was causing the problem.
Thanks for the replies
Sharunda
Jun 16, 2008
4,987
1,085
One Horse Town, New Jersey
@Billybobvi Glad you worked that out. My DH want this same set up for his iP6s+ and I warned him that he should not get the Zagg and put it on under that Otterbox. Now I have proof that it will be an issue.
Nov 9, 2012
137
Get a THULE Tough case also you don't need a screen protector,unless you use sand to clean the phones screen.
