Labyrinth 1.0.3 "Freed" ;)
kariya9mdoa
Oct 26, 2007
80
How to install:
Get it from any of these
http://www.mediafire.com/?xdw5y5mnmvs
http://premium.fileden.com/premium/2007/5/25/1110195/labyrinth-1.0.3.rar
http://rapidshare.com/files/100381964/labyrinth-1.0.3.rar
1. Labyrinth.app under /Applications
2. Other files under /var/root/media/
3. Remember to set permission to all of the files to 0755 (You should do this every time you put any files manually trough SSH)
4. And the "Download New Level" is working (remember to switch on your WiFi)
Tested on my 1.1.4, WORKS
HappyModding
Bone
Feb 11, 2008
1,214
How to install:
HappyModding
w
Is this a good idea?
Jul 6, 2007
1,832
26
Marietta, GA
about.me
hey, when i went to use it there were no level packs, or anything available for download. When i was setting the permissions to 755 I noticed a bunch of folders that were zipped with different people's names. Should I unzip them?
depthnerd
Feb 16, 2008
1,280
Yeah...this doesn't work for me.
knight12
Mar 22, 2008
Many thanks ! But the "Download new levels" doesn't work for me...
I've put everything in the right place, changed permissions and when I try to play, since there's no level pack included, I use the + symbol > I see a list of levels > I tap on one to download it, and nothing's happening.
Suggestions ?
depthnerd
Feb 16, 2008
1,280
I tap the plus, and I don't even get anything showing up.
kariya9mdoa
Oct 26, 2007
80
oops forgot to say, set permission for all the files to 755 it should work
kariya9mdoa
Oct 26, 2007
80
the level pack is inside the rar that i uploaded for you
just upload in you iPhone to the following folder
var/root/media/Labyrinth/Levels/
and any files inside the rar file must be transfered, levels should be there and no need to download
when i try to chose download level, the screen is blank, most probably because no new levels available, but who knows? cant expect much from "freed" version
kariya9mdoa
Oct 26, 2007
80
you should have this
Application/Labyrinth.app
/var/root/Media/Labyrinth/images
/var/root/Media/Labyrinth/levels
i don't think the program will work if you put on /var/mobile/Media/Labyrinth
set permission to 755 for ALL the FILES
depthnerd
Feb 16, 2008
1,280
If I do that there should be files to download, correct? If so, there aren't.
kariya9mdoa
Oct 26, 2007
80
set permission to 777 for ALL the files, and after that, the progress will be saved just fine
testd on 1.1.4
set permission to the folder doesn't mean you set the permission to a every single file within the folder (no exception), hope your program can use "select all" and then set ther permission
knight12
Mar 22, 2008
Doesn't work for me either... ALL my permissions are changed, and I have all the right files at the right place......
EDIT : Got it to work... I've deleted it and installed it again with the permission 755... I did nothing different than the last time...
Thanks !
kariya9mdoa
Oct 26, 2007
80
Hey guys i just found the solution after numerous attempts
rem after running the game for the first time, go back to /var/root/Library/Labyrinth folder where you should be able to see 2 or 3 files inside now (this folder used to be empty when u first copied it over), now highlight the contents and set everything to 0777. Restart your iPhone, then play. Enjoy the game.
Put all to their files for 1.1.3 and 1.1.4 the same.
Then change permission for all files in
/var/mobile/Library/Labyrinth
/Applications/Labyrinth.app
to 777
And create symlink using putty
ln -s /var/mobile/Media/Labyrinth /var/root/Media
kariya9mdoa
Oct 26, 2007
80
Or you can try this
undid all the things i have done... to start from scratch
things to do:
1. install the original labyrinth demo from installer.app
2. download the 'freed' version
3. copy the 'freed' version to replace the original demo version (in the applications folder and also the var\root\Media folder)
4. a brand new working game
advantages of doing it this way.
the original demo version will help u create the file permissions required and also put the files into the correct folders.
u can uninstall it using installer should u get bored of the game
cheers!
depthnerd
Feb 16, 2008
1,280
Ok now I know. You're stealing this directly from a site without even trying probably. I've tried everything and it's obvious that it fails to work.
