Late 08 MacBook slowing
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
I have a late 08 Macbook that seems to be freezing/slowing down a little more than before. Are there any programs out there that work well to clean up and make it work a little better?
I have 4gb ram . 1TB hard drive that's been in for at least two years
It still works well but i don't remember seeing the spinning wheel as much as i do now
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,780
Long Island, NY
I would recommend using Disk Utilities (Applications/Utilities/Disk Utility) to repair permissions. Over time and with each installation, I've found these can be off. If you are looking for a tool to clean up your Mac, I highly recommend CleanMyMac 2. I've used it for years and it does a great job. I use it more to free up disk space, removing files that I no longer need.
What operating system are you running?
Kadelic
Jan 4, 2010
4,948
1,647
Dallas, TX
In addition to using Disk Utilities to repair utilities, you can also verify and repair the HD itself. I repair permissions and the disc occasionally on my 2010 MBP and it seems to help.
I also recommend CleanMyMac as a handy tool. I also use Onyx (free) to periodically run clean up and diagnostic checks. It's a bit more complicated than CleanMyMac but I only use a few of its basic features.
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
Repaired permissions yesterday and it seemed to make a difference.
Checked the drive it was fine
