Hey guys, i was wondering if anyone get this weird problem on the latest version (and even previous versions) where my keypad is no where!
i mean, the keypad is gone!
check the picture. anyone know how to fix this problem?
thanks
It's not that it's turned off, it's a different sort of input pad. Instead of tapping where the buttons would be, you can just slide your thumb around on the pad.
