MacBook Leaving my PC need advice...
LEFP4
Dec 1, 2011
Hi everyone I've decided I want to get a mac for my laptop instead of a PC for college. I know I want something fairly high end, but not suuper expensive (around the 1-1.2k range). What models would you suggest I go for.
Also I've heard that Apple has good deals for college students sometimes. Haven't they like given out free ipods or something?
What do you think would be the best laptop for me?
15,385
1,023
Yeah, in past summers, they've given students iPod touches with new macs. I don't think they did it this last summer, though.
rambo47
Apr 4, 2010
528
79
Northern NJ
I always used to buy the 15" PowerBook. That's back when the choice was between iBook (consumer model - todays MacBook) and PowerBook (professional model - MacBook Pro now). The difference in performance between these two models was dramatic and even an "inspired amateur" like myself could appreciate the difference. Today the gap between MacBook and MacBook Pro is much slimmer than in days past. I would recommend a top-of-the-line MacBook. Max out the RAM and you're good to go.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Yeah, I don't like that. For 900 bucks, especially for a student that already has plenty of debt , you could've gotten yours self a Mac. My girlfriend is very happy with hers.
LEFP4
Dec 1, 2011
So if I got a MacBook Air, I could stay in my budget and it would work for all the things I need to do in college, i.e. research, projects, documents etc. ?
15,385
1,023
Just make sure you can live with an 11 or 13 inch screen. That's probably going to be the biggest drawback if it'll be your main computer. I'd also suggest to go with a model with 4GB of ram to help with multitasking. It's not upgradable on the Airs, so you've gotta make sure it'll last.
LEFP4
Dec 1, 2011
What with the education store? Do you have to provide certain student information?
RedWritingHood
Jan 22, 2011
139
MO
I'd consider what you'll do if any of your coursework will require a program installed through a CD, as the Air doesn't have a CD drive. (at least that I know Of...There is likely a way around it, but I don't know what that is.)
I'm enrolled in college as well, and when I go to my college's student bookstore website, there is a link to Apple's student page. Not sure beyond that what you'd have to do.
Good luck!
DrixO
Oct 28, 2011
I can't say from personal experience but from what I've seen other people say is that Apple doesn't verify if you're a legit student or not.
LEFP4
Dec 1, 2011
What's the deal with refrubs? Can it be risky buying one because they've been used?
