Led notifier not working with custom vibrate ?
Smiffy403
Dec 24, 2011
30
Hey, I guess the title says it all so has any 1 else come across this ? I have checked its turned on and done a hard reset. But still no joy 8( I'm running iOS5. Any input would be greatly appreciated
Thanks Dave.
Sent from my iPhone 4S using iCafe app
~DS~
Dec 18, 2011
140
No the title does not say it all, you need to be more specific. From what I understand LED only works when it's in standby.
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
I had to turn LED on, open the camera, turn flash OFF, then turn phone off. Turn back on and check LED.if it works, then change camera setting back.
Smiffy403
Dec 24, 2011
30
Sorry DS looking back I have to agree with you ! I'l start again lol. Right, If you use the standard vibrate that the 4s comes with the led work fine when you get a text etc but if you make your own custom vibrate it doesn't work
Smiffy403
Dec 24, 2011
30
Kgd was that using the custom vibrate as my led works fine with the standard 1 but not the custom vibrate. There both nice little features just a shame mine don't seem to work together
Thanks for your input both of you 8)
~DS~
Dec 18, 2011
140
If you reboot recently...it breaks the LED, you need to disable and enable LED again. With custom vibration on and LED on...it's working fine on my end...
Sent from my iPhone 4 using iCafe app
Smiffy403
Dec 24, 2011
30
Ah ha ! That's done the trick 8) thanks both of you ! Just 1 more thingy though DS do you have to do this on yours every time you reboot ?
~DS~
Dec 18, 2011
140
Kinda, there's no other way around it. It's an bug since iOS 5. :/
Smiffy403
Dec 24, 2011
30
Ah ok, well I think I can live with it... the rest of the phone more than makes up for it ! Cheers for your help !
