lens scratch? replacement?
Jan 16, 2008
NY
I lens (the small circle of glass over it, I think) seems to be scratched. When you look at it at the right angle you can see all these lines and my pix all have that soft focused look. I've tried cleaning it with a microfiber clot, but it did not help.
Does any one know if this is a replaceable part?
Oooh! I just did a different search (my first on did not find it) and found this:
http://forums.everythingicafe.com/threads/iphone-camera-lens-ar-coating.18591/
Looks like I'm not the only one.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
This is something I've always wondered about myself. Unfortunately I haven't heard of this happening that often so I don't really know what procedures could be taken to fix it. I would think Apple would be able to fix it for cheaper than the typical $250 repair fee. If you've cleaned it thoroughly several times (the lens that is) then I would recommend restoring (if you're Jailbroken and/or Unlocked) and then visit your local Apple store. It might also be something that you can fix yourself but I'm not too familiar with self-replacement jobs.
Quake97
Jul 10, 2007
522
Philly Burbs
Well, it won't be covered under warranty, but technically you caused the damage.
Joe
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
As Seen on TV
Have you tried this:
https://www.officialtvwebsite.com/lensdr/ver2/index.asp?did=644&refcode=lensdrg
It's been on TV, so it's got to work! ;)
