Leopard on the PC.
wjp09
Feb 25, 2007
2,559
25
NJ
BUY LEOPARD. WE DON'T CONDONE PIRACY. CONTINUE STEPS WITH A PURCHASED VERSION.
http://dailyapps.net/2007/10/hack-attack-install-leopard-on-your-pc-in-3-easy-steps/
Here are the things that you will need before Install Leopard on your PC…
  • The Patched DVD Image
  • The zip file containing the patch
  • One pen drive or USB Flash Drive formatted as FAT32
Well once you have all these you can go ahead and Install Leopard..
Step 1. Getting things ready
  • Burn the DVD Image onto a Single Layer DVD-R using a software like Nero.
  • Format the USB Flash Drive and the drive label should be "Patcher" without the quotes. Please note it has to be "Patcher" only and nothing else for the patch to work when we apply it later.
  • Extract the Zip file and put its contents into the USB Flash Drive.
  • Now your USB Drive should contain a folder called "files", if it doesn’t then check to see where you have gone wrong.
Step 2. Installing Leopard
  • Now that you have the Patched DVD with you, you can now install Leopard. Pop in the DVD into the drive and boot into it by pressing F12 at the BIOS Prompt.
  • Boot into the DVD and the installer should now load. It take a while though, so be patient.
  • Select your Langauge and make sure you select Customize and you need to deselect all the packages that are displayed.
  • Leopard will now install. This can take a while, so go grab yourself a coffee.
  • It will ask you to Reboot, so go ahead and Reboot. Before rebooting make sure that USB Flash Drive is connected to the PC.
Step 3. Patching Leopard
  • Now that you have got Leopard installed, you need to patch it. Before we do that Boot into the Leopard DVD like the way you did before.
  • Wait for the Darwin Bootloader to load. Once it loads up press F8. You should now see a prompt. Type -s and hit enter. The DVD will now load in Verbose mode. Watch for any errors. It should load without a problem because you have already installed Leopard.
  • Once the setup is loaded select your Langauge. Once done you should now be seeing the Welcome Screen. Once there navigate to Utilities-Terminal.
  • Once the terminal loads up, you now need to browse to your USB Drive, so follow the steps below, typing it exactly as it appears below in the Terminal. In the command line type the following as they appear here
    cd ..
    cd ..
    cd Volumes
    cd Patcher
    cd files
    Notice the space between cd and the 2 dots.
  • Now its the time to run the patcher to make sure Leopard will work on your PC. Type the following into the Terminal. ./9a581PostPatch.sh
  • The Patch should now run. You can answer Yes while removing the ACPUPowerManagement.kext
  • After the Script is done, you should now be able to Boot into Leopard after you restart.
Step 4. Congratulations! You’ve done the Impossible!
Kabeyun
Jan 10, 2007
665
Northeast US
This post is borderline, as it promotes copyright voilation but doesn't actually contain illegal content. Any posts with links to a hacked Leopard DVD image aren't borderline. They will be deleted and the poster banned. Apple wants you to purchase their OS. Anything less is stealing.
-K
