Let's talk iOS 7.1 beta 3
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Apple has released iOS 7.1 beta 3. The update is available OTA and via the Apple Developer portal. Here's the complete changelog and release notes.
Notes and Known Issues
The following issues relate to using iOS SDK 7.1 beta 3 to develop code.
Bluetooth
Known Issue
32-bit apps running on a 64-bit device cannot attach to BTServer.
CFNetwork
Notes
A compatibility behavior has been added to address an issue where some web servers would send the wrong Content-Length value for “Content-Encoding: gzip” content. Previously, NSURLConnection and NSURLSession would send a “network connection was lost” / NSURLErrorNetworkConnectionLost (-1005) error in this situation.
The compatibility behavior applies only if the Content-Length value exactly matches the expanded gzip’d content. It won’t apply for “off by 1” or similar miscounting.
iCloud
Fixed in iOS 7.1 beta 3
Creating a new iCloud account during setup assistant, should no longer give you an error when you enable iCloud Keychain.
Messages
Known Issue
Messages sometimes indicates iMessage send failure immediately after sending.
Workaround:Tap the error icon to re-send the message.
Music App
Audiobooks now play as expected.
Safari
Notes
A property, minimal-ui, has been added for the viewport meta tag key that allows minimizing the top and bottom bars on the iPhone as the page loads. While on a page using minimal-ui, tapping the top bar brings the bars back. Tapping back in the content dismisses them again.
For example, use <meta name=”viewport” content=”width=1024, minimal-ui”>.
UIKit
Known Issues
  • If a UITextField or a UILabel that is baseline aligned with constraints has attributes that change after the constraints have been added, the layout may be incorrect. The exception to this is -setFont: on UILabel, which should work as expected.Workaround: Avoid making changes in UITextField or UILabel after adding baseline-alignment constraints. If you must make changes, you should remove the constraints and then reapply them afterward. Note that this is a performance hit, so don’t do it unless it is necessary.
  • The backIndicatorTransitionMask from a storyboard or a xib will not be interpreted correctly at runtime.Workaround: Set the backIndicatorTransitionMask in code.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
The incoming call screen... no more photo caller ID? That's a somewhat radical change. I hope we at least have a setting to show the contact picture of the caller, and are not simply forced to look at a black background... (or that this doesn't make it into the final release).
incomingcall.jpg [thumbnail, click to enlarge]
(Disclosure: I have "lifted" the screenshot above from elsewhere on the Internet. I am not running iOS 7.1 beta 3 myself.)
TomKlyn
Nov 19, 2013
52
Iowa
facebook.com
I just downloaded it at home might install it tonight it's staring to look better
And just so everyone knows
Beta expires on Monday, February 10, 2014 @ 12AM (GMT)
Sent from my ARM64
jmatheron
Sep 11, 2013
Don't like the keyboard they changed it back to the old style much preferred ios 7 one, what do other people think?
15,385
1,089
it's still the ios7 keyboard, just tweaked a bit. mostly just a thicker font used for the characters.
TomKlyn
Nov 19, 2013
52
Iowa
facebook.com
It doesn't look bad though I also had the App Store ask if I wanted to enable auto updates in the first open
Sent from my ARM64
TomKlyn
Nov 19, 2013
52
Iowa
facebook.com
Sent from my ARM64
I was reading some other sites the tweak coders don't support the beta iOS so went back to 7.0.4 for the time being
Sent from my ARM64
