Life proof 5 nuud question
radtechy
Jul 20, 2011
496
41
I remember from having otterbox defenders that the edges are tight to move icons around so I was wondering if the nuud which is raised from the screen causes any issues sliding up the control panel and sliding the notifications down.
Sent from my iPhone 5S using Tapatalk
Mthoroughbred
Dec 16, 2008
741
100
43
Yes. It can be annoying at times. I had it for the iPhone 5. Another thing is control center. You have to keep swiping till you can find the "sweet spot" lol
28,365
5,506
My apps are always up to date
Sent from my iPad using Tapatalk
Can you disable the Tapatalk signature from your posts then? Your signature is a link to Tapatalk and it's showing up in every one of your posts and again every time someone quotes you. You may not see it in the app, but it shows up in mobile safari and on the full site.
Ledsteplin
Oct 29, 2013
4,796
979
65
Florence, AL
I changed my TapaTalk signature to say "Apps" instead of "TapaTalk" in the TapaTalk settings. I don't use it much for this forum, but do on others like tidefans.com.
