Lifeproof case
6,682
49
After going over it for the past 15 minutes, I see no real way of compromise here. The indented home button on the screen cannot operate like the home button on the phone. That is why the square is there.
Oh well. Rolling naked right now. I'll put the case back on later.
mrbunglez
Mar 20, 2008
439
100
43
Disregard my other post, i just received a call from customer service @ LifeProof out of the blue and wasn't expecting it about my order(s). She sounded genuine and wanted to help me with my issues. I am now truly impressed with how they deal with customers issues.
6,682
49
Yes, I hate to say it, but I think the staff rotates to handle emails, and it's not exactly working like it should. But they do believe in their product and genuinely want to solve any issues that a customer might have.
Target
Oct 16, 2008
1,139
168
The Great State of WV.
Well... I've used the LifeProof case for a week or so now and while, there are many reviews out there, here is my two cents: Over all, I like the case. It has a great feel, its slimmer and works in my pocket better that my other silicon & otter box cases. Most days I have a plastics snap on case that used because it fit my pocket better. I have a better sense of security for everyday bumps and the dreaded drop, but think it's too thin to provide real protection of the front & back glass should it get pressure applied in a twisting or benting motion. Ya know... if I sit on it. I did the water test and the inside stayed dry. I have yet to get the guts up to put the phone under water. I do think that should it happen to get submerged, the phone would be fine. But how often do I really worry about it getting wet?
Now what I'm not thrilled about: the screen is high gloss and shows every little print and smudge. I really hate this. I had a removable, washable screen protector on it that was a matte finish and showed no finger prints. I never removed it in my OB. I am thinking of putting back on under the LP case. I realize it's not recommended, but can't see why it would hurt. Neither my old screen cover or the LifeProof changed the look of the retina display. So no worries there. I do use my MP3 hookup daily in the car and this adapter is a pain. Don't get me wrong, I'm tickled they sent one, but its cumbersome to use. I use the Apple headphones at the house that fit but keep an other set my gym bag that do not. So if I forget the adapter, I would have to remove my iPhone from the case. This is a downer as the gym is where I really need protection. I don't like that the iPod connector in my truck doesn't fit in the case and the solution is a $20 adapter. IMO that is something they should have included as well in the price. It was a bit spendy, but I bought it anyway. I'm going to agree with Hawk, that the fit could be tighter with the screen. The waterproofing over the speaker as well as the rubber block on the home button causes this, but as he said, you get used to it really quickly.
The last issue that I really really don't like, and it's the biggest, is the sound of speakerphone. While I think this case gives music and video better sound, and I'd even say enhanced sound quality; on speakerphone calls and facetime chats, this case makes the speakerphone useless. I think that the special back cover allows the sound to resinate and over power the mic as well as the noise canceling mic. This single issue may be the reason, I would not use this case every day. The people on the other end of a speakerphone call or a facetime call tell me that they loose every other word. On my end, I also lose every other word. I have adjusted the volume down until the sound clears, but then the volume is too low. This should be something that needs addressed and fixed by LifeProof. I'd even say they should send out replacements. If you have one of these cases and do not experience this, I'd love to know so I can investigate why mine act this way.
There you have it. A real-life review. I'm a traveling, and very active, marketing guy who has been relentless in searching for a great case for my iPhone. The journey will continue. This one gets three maybe another half, stars out of five from me. Special thanks to all who posted about this case. It was helpful in my decision to try this case. Now I'm just sharing the love...
Target
IllusionEntity
Jun 3, 2010
1,987
163
Borough Green, Kent, UK
Target
I agree with most of the review. But to play music I open my charge port. The music makes a sort of rattling sound when I play it without it open
6,682
49
Wanted to give a quick update to my tinkering with the home button of the case. I found the perfect compromise.
I used 2 pieces of Scotch packing tape, cut about 1-2 mm smaller in diameter than the "home button" stacked on top each other. It's only a fraction of the thickness of the square, but it kept my screen responsive, as well as the home button. it's not 100% perfect, but I find it much better than before.
Might add one more piece of tape to make it 3 layers, but it seems great right now, so I may not.
6,682
49
2 layers is perfect. 3 and it starts acting like before
6,682
49
Just a clarification. the tape I used was the clear Scotch packing tape. Kinda thick on it's own compared to regular dispenser tape found on an office desk.
One other thing. DO NOT use anything with an edge to remove the plastic square. The inside is painted and scratches very easily. A fingernail is all that is needed, and I had to keep picking at it slowly. I did try with the edge of a pair of scissors and made a fine line scratch in the paint. The tape covered it up, so it's not noticeable from the other side.
Target
Oct 16, 2008
1,139
168
I did attempt to open the charge port on a speakerphone call today and it may have helped my previous issue. More testing is needed.
Target.
6,682
49
According to LifeProof's official response, they did get a number of orders for a 3G/3Gs version, but it was not enough to move forward with.
I believe that the cost of development and production would have been higher than the sales. No offense to 3G/3Gs owners, but it's about time to upgrade.
IllusionEntity
Jun 3, 2010
1,987
163
+1
PinkBanana
Feb 16, 2010
1,476
94
Burnley, UK
Maybe some people can't afford to upgrade.
6,682
49
I didn't say whether it was right or wrong, only that the demand wasn't high enough to warrant making them
Phreddyl
Jul 28, 2011
138
No u didn't but what u did say was that maybe it's about time to upgrade.
He opened with no offense. I really can't imagine any case makers investing any time or money into a phone that is over two years old. I would think a large majority of 3G owners are holding out for the 5 and wouldn't spend $70 on a case.
