Lightning cable
luislahud
Jan 10, 2009
61
Hello, I need to buy an original lightning cable on Ebay. One of them says for iPhone 5 or 5s. My question is, "Can i charge my iPhone 6 with with a iPhone 5 lightning cable, are they comparable?
Thanks in advance!
Sent using iCafe app
A lightning cable for the iPhone five and 5S is exactly the same as the six. I am not sure what you mean when you talk about heat shrink tubing, it certainly can be used to reinforce the cable by placing the cable inside tubing, and shrinking it tight. If you want to make sure you get an Apple approved cable, look for the words, "Made for iPhone ..." or MFi certified name and logo on the description.
luislahud
Jan 10, 2009
61
Thank you I need an extra cable to charge my phone in my car that's exactly what I wanted to know.
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
I've always been a bit confused by the MFi designation. Does this mean that the cable will pass audio as well?
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Was there a post or a portion of a post removed by someone? I don't see where the OP mentioned anything about heat shrink tubing.
Thanks in advance!
I know that you did not ask about this, but I figured it couldn't hurt to tell you... If you haven't committed to the purchase of that iPhone 5 lightning cable and adapter you mentioned yet, you may want to look at some 2.1 amp AC chargers. These will charge your iPhone 6 quicker than an iPhone 5 cable can. The charging adapter that is included with an iPad is capable for delivering 2.1 amps (it's available for purchase separately), as are any of the ones discussed in this article. If none of those tickle your fancy, you can look at more adapters here.
The lightning cable has nothing to do with the amperage of the charge, that is determined by the charging adapter that is plugged into the wall. The cables are interchangeable with any adapter.
And yes, the original post includes A mention of shrink wrap tubing that wasn't quite clear to me it doesn't seem to be there anymore
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Thank you, I edited my post to be more clear about that =)
I guess my point is that you're mentioning that it will charge faster than the iPhone 5 cable can. The iPhone 5 cable the iPhone 6 cable are identical, and neither has anything to do with how fast the device charges.
I get what you mean. The lightning cable needs to be connected to a higher amperage charger in order to get a quicker charge time.
5,578
I know what it stands for, but I'm still curious to know if any third-party lightning cables pass audio.
I'm curious about that as well. They all seem to say "charge and sync" and I didn't think they did, but then @acosmichippo said that he had one that does about a year ago. I'm pretty sure it was a Monoprice. I don't have any third party cables. I know that none of the cheap ones pass audio, at least. Apple just barely licensed the connector and specifications, so we should start seeing a lot of third party cables that integrate the Lightning port and pass audio in the future.
15,385
1,089
I use a monoprice cable in my car with my head unit. does CarPlay and everything just fine. but my favorite lightning cables now are the Amazon basics cables. they're super robust and very inexpensive.
Dec 15, 2008
5,386
340
Pensacola, FL
What does it mean for third party charger cables to pass audio? I have and have had charger cables that cost only a dollar, and they work perfectly. I have been helping the person who gets them, to let him know which ones are good that don't break etc.
5,578
They don't work perfectly. I guarantee you that a $1 Lightning cable won't pass audio. I doubt it will last as long as a good cable, either. Passing audio means you can plug it into a USB post on a stereo and have music come through the speakers. This isn't importort for a lot of people. Most people just use their cables to sync and charge. If you use the cable to connect to a car stereo via USB, it has to be able to pass audio. Otherwise, you'll just get a "this accessory is not supported" message.
Dec 15, 2008
5,386
340
Pensacola, FL
Oh I see. I don't think I have a way to test it. For my car I use a cable that goes into car port then iPhone and I can call people and listen to music through radio. As for not perfect, I have been using the same cable for a long time now. Finally I found one of his that doesn't break or show wear or tear or just stops working. I'm happy. However, there is one small issue. Every now and then you may plug it in to your computer and it'll cause your computer to shut down. Weird.
5,578
It sounds like you're using the auxiliary port (AUX) and an FM transmitter. Yeah, you don't need it to be able to pass audio for that.
The computer is set to reboot with serious errors. The cable might be overloading the port and crashing the OS. If it's a PC, it could be a problem with the USB drivers. I'm pretty sure you have a Mac, though. Problems with the Motherboard/Logicboard or power supply can cause this as well. This only happens with the cheap cable? Does it only happen in one of the ports? If so, don't use that cable with that port.
