Lightning to Micro USB adapter!
iphonewarrior
13,847
699
Whoah! didn't know you could get those! Thanks man!
Darn. I cant order from the US.
Try changing to the US store, that link goes to the UK store... just sharing the wealth! I didn't know they even did them until about 20 minutes ago :p
theorioles33
Jul 21, 2007
925
135
USA
I didn't see them in the US store. I did a quick Google search and saw that it was only for Europe. :(
jmp316
Jul 10, 2008
1,048
141
There are some sellers on eBay that sell them, but they are quite expensive at the moment.
I'm still holding off on a bunch of 5 accessories until more comes out and prices go down...
  • Like
Reactions: iphonewarrior
radtechy
Jul 20, 2011
505
41
I would love to order this but is there a certain type of micro USB to use with this?
Like volts & amps? I don't wanna get my phone fried.
I remember hearing that you shouldn't use a blackberry charger for a droid just to give an example
Sent from my iPhone 5 using iCafe
So that's converts to about $24 US dollars. The price is twice that on eBay right now.I found out why it's only available in Europe:
"But why only in Europe?
In 2010, the European Commission picked Micro-USB as the official standard, requiring that all smartphones available in Europe be compatible with the interface. Apple was able to get the okay for its 30-pin dock connector by offering a Mircro-USB adapter"
Lon
Jun 5, 2010
2,946
132
Alaska
So IPWarrior should buy a bunch of them and send them to all his friends here on the Forum so we have another option also! :ROFLMAO:
Lon
Jun 5, 2010
2,946
132
Alaska
BTW. What do they look like? Do they have the pigtail, or are they a direct connect like the $29 adaptor?
So they may not have the same issue attaching to the iPhone with a case as the 30 pin to Lightening adapter?
No, it looks like it's about the same size as the Lightning connector (it might be slightly larger just like the 0.2 m cable port is), so it should work with most, if not all, cases.
Lon
Jun 5, 2010
2,946
132
Alaska
Okay then. Who in the UK can get us some of these? :)
Lon
Jun 5, 2010
2,946
132
Alaska
So, for us perhaps less technically inclined, if Apple can achieve the same connectivity through a micro USB cable, why not just use the Europian and more generally utilized micro USB connector without having to use an adaptor?
Lon
Jun 5, 2010
2,946
132
Alaska
Thanks for the offer. I will keep that in mind in case I think I could use one later.
radtechy
Jul 20, 2011
505
41
They are now on the Apple USA website. And guess what I just got my 0.2 mm lightning to 30 pin adapter today
radtechy
Jul 20, 2011
505
41
Anyone knows of this will fit with a lifeproof fre on an iPhone 5?
The lightning to 30 pin 0.2mm adapter fits with enough room to spare. I'm assuming this is smaller but I can't get any size info on it
Sent using iCafe app
