Lightning USB cord stuck in USB port
PapaST
458
I have a feeling they might be making the "green dot" lightning cables to discern between the old and new cables. The deep holes do not affect everyone. It really depends on the USB slot you plug into. If the four USB prongs aren't designed a certain way then they will sink all the way into the 4 USB holes making it very difficult to pull it out.
I finally got mine out. For my situation "wiggling" didn't work. I used a small screwdriver to pry it out just enough to extract.
imutter
Apr 4, 2011
5,994
775
Somewhere between DC and Baltimore.
I am sorry I did not understand "green dot" Am I missing something?
I am asking because I noticed a green dot on the charger part of the iPhone5.
PapaST
458
I was just speculating. Back in the day when there was an issue with the plug in charger Apple corrected the problem and released the charger with a "green dot" signifying that the charger was a fixed one. If they deem these USB cables to be faulty then they might release later Lightning USB cables with a "green dot" signifying a fixed cable. Who knows. I was lucky because I removed mine relatively easily but others I've seen were not as lucky.
