Limbo app
Docd
Oct 16, 2011
650
66
On my daughter's 5s her twitter app has disappeared. When I go to the App Store to reinstall it it says OPEN as if it's installed on her phone, when you tap OPEN it does nothing. The app is nowhere to be found on the phone and several reboots and hard resets did nothing. How can I get the app back on the phone?
Sent from my iPad using Tapatalk
28,365
5,506
Delete the app in iTunes on her computer and sync. Once it's removed, you can reinstall it in iTunes and sync again or just install it on the phone.
Docd
Oct 16, 2011
650
66
Phone has not been synced with a computer only backed up with iCloud.
Docd
Oct 16, 2011
650
66
UPDATE
Issues resolved itself when updated phone to 7.0.6
Sent from my iPhone using My fingers.
