Limited Space (8g) on iPhone: Any Pros/Cons to JB'ing?
pike942
Jun 10, 2008
9
With only 8gigs of space, I'm constantly running out of space! Would jailbreaking provide any solutions to this problem? …say, in conjunction with a wireless thumbdrive? Could apps be run off the drive like the old PalmOS Springboard?
28,365
5,507
Jailbreaking won't help with this problem. Apps have to be installed on the the built-in storage. You have a couple options: DropBox-type cloud storage or a iPhone-supported flash drive.
pike942
Jun 10, 2008
9
I figured as much. Thanks. I have a similar drive. Of course, it helps with the media; but I can't fit enough of my favorite apps! Must upgrade to larger capacity device!
