Line out on White Dock
PhilipJohn
Aug 24, 2007
163
Bronx, New York
I guess I hadn't really noticed it before, but on the back of the white dock that came with the iPhone is a "line out". Does anyone know what that is for? Thanks?
psylichon
Oct 31, 2007
16,591
751
40
Philly
Think of it as another headphone out... the difference being it shouldn't respond to the iPhone's volume setting (I don't have mine connected at the moment, so I can't test if it does or not, but a true line-level output should have no level adjustment on it)
You would likely use it as an easy, semi-permanent connection to a stereo system while you're docked.
One thing worth noting: there is no recessed jack on the line out, so normal headphones and cables work without an adapter...
psylichon
Oct 31, 2007
16,591
751
40
Philly
No problemo.
And just out of interest, I tried the line-out and it indeed does not respond to the volume control on the iPhone. Good on you, Apple!
rgarjr
Nov 19, 2007
34
I bought a universal cable, 30 in dock to line level rca audio outputs and when i hook t up to the iPhone, no audio comes out ofthe rcas. I tested my brothers 50 dollar cable, the one that has the video out as well and that one works, it mutes the internal iPhone speaker and sends the audio out.
