Linksys wireless connectivity?
Jan 27, 2009
I am putting the password and the name of my router into the authentication field and it still doesn't work. Any ideas?
6,682
49
make sure that you are putting in the password correctly. That's basically the only thing that would cause problems since the iPhone does not have any other settings. Or at least not until after you connect.
The only other thing it could be is the wifi card is malfuntioning. Test by taking the security off. if you can connect like that, then change your password to something you can type on the iPhone easily.
6,682
49
is it an 802.11n network?
THAT, is a damn good question Hippo... But by default, wouldn't the router be open to both B and G signals as well? or would they make N only the default setting?
15,385
1,089
could be either. Most "N" routers have settings for either a "mixed" network that is compatible with b, g, and n devices, OR you can set them to "n only" which will boost the performance.
I have my Time Capsule creating an "n only" network, and my iPhone sees it as available, but will not connect.
this is why i hop Apple will introduce an N receiver into the iPhone soon... while it won't benefit in the performance at all (unless they also add wifi-syncing), it WILL promote smoother 802.11n use overall, which is important for other Apple products like Time Capsule and Apple TV.
kenneth
Aug 19, 2008
1,465
Texas
Call linksys tech support. They are 24 hours and they will get you fixed up and install all the updates to your routers.
chrisbpr
Jan 28, 2009
what worked on my router was changing the security from WEP to WPA,worked a treat from then on.
although not a linksys router ( mines a billion) WEP security can cause problems.
s8n666
Oct 3, 2008
66
Make sure that your router isn't mac address locked. You may have to add your iPhone mac address to your router list of accepted mac addresses.
