Live Wall Paper App
TheAtreidesHawk
Jun 7, 2010
98
I just want a simple app that shows me a list of different live wallpapers for the iPhone 4. Previews of these apps would be cool but if not it's not a deal breaker.
Can someone provide me with a few names of apps that do this and more importantly how to install them through Cydia and how to access them?
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
The only way I know how to get this effect is through vWallpaper of which the "v" stands for video. It does give you the option to preview them before you apply it. I actually even made a few of my own that I use as animated wallpaper. The cool thing is you can have sound as well. Make sure you have iSpazio repo added and you should be able to find it in Cydia.
morth58
Mar 17, 2008
174
Hey Watcher, is this working on your iPhone 4? It just closes right away on mine.
iphonewarrior
13,847
699
You're welcome. I actually only had to do steps 1-5 to fix the problem. Try that first and then do 6-8 if you still get the errors. I used iFile to edit the Cydia.list and delete the bad 'deb iSpazio' address.
iphonewarrior
13,847
699
I can confirm that this worked perfectly, I did everything through SSH. I used Text Wrangler (Mac) to edit the file and everything is now back to normal.
