Loading my own mp3's and movies on iPhone
Skyraker
Jul 9, 2008
Before I plunk down $300 for the new iPhone I want to know if I can plug the iPhone into my Win-XP laptop (via USB cable) and download my own personal mp3's and movies to the iPhone?
Can you do that, or does everything have to go through iTunes?
Thanks!
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Thanks!
It has to go through iTunes. There were some jailbroken apps that allowed a workaround, but for the stock firmware, it must go through iTunes. You can use software like videora for iPhone to convert your movies that load the movie into iTunes after conversion. It's not a big deal.
Skyraker
Jul 9, 2008
When you say it has to go through iTunes, do you mean I have to re-purchase all my music from iTunes if I want it listen to it on my iPhone?
Luckykelleyk
Jan 12, 2008
1,737
33
Denver, CO
you should be able to import the files into iTunes from your computer.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
any mp3 you have, purchased or not, will load into iTunes and onto your iPhone.
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
If they are your personal, non-DRM'ed MP3's (ripped from CD, for example), then yes. However, if these are DRM-protected files, like from one of the online music stores or Zune music files bought from the Zune Marketplace, then no.
Someone correct me if I'm wrong. I don't think iTunes can decrypt Windows Media Player protection, right?
Luckykelleyk
Jan 12, 2008
1,737
33
Denver, CO
It depends where you bought them, there are some sites where you can purchase non-encrypted mp3s.
Luckykelleyk
Jan 12, 2008
1,737
33
Denver, CO
That's why I mentioned the phrase, "if these are DRM-protected files". ;)
well you did say "If they are drm-protected files like from one of the online music stores "
if we are going to get picky about it ;-)
eye-Fone
Jul 5, 2008
1,024
14
If you want to get picky ;) then that statement doesn't not necessarily mean all files from those places are protected. Even if I say, "the majority of DRM music are bought from online music stores", it doesn't mean that all music from those stores are protected.
At any rate, I think the OP gets the message. :p
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
No. You just import them into iTunes. With music it's simple. With movies they must be converted with videora for iPhone. Videora for iPhone will import the movies for you at the end of the conversion process.
kevlar08
Jul 3, 2008
1,140
Colorado
Thanks!
you have to use iTunes, its really simple to get all your music and movies onto iTunes, then you just sync with the phone
