Loading the Manual Order screen
dobymax
Oct 19, 2007
238
I JB'd with ZiPhone and used Timnan's instructions. Everything works fine except when I try and put only two icons on my screen, it never takes and stays the same. It says to save these changes, load the Manual Reorder screen. When I go to that screen and put my two icons in the dock, where do I save it? Or where do I load the Manual Reorder screen? Thanks in advance.
Oct 4, 2007
537
San Francisco
That part of customize doesn't work at the moment. If you want to hide some icons use an app called "poof" and if you want 2 icons in the dock drag and drop the apps you want to the dock.
