Location Services remain on with iOS 5
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
Like the title says. Little purple arrow on status bar. Has been on since I loaded iOS 5. Is this normal? BTW I am using findmyiPhone through iCloud.
Thanks in advance.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Mine was too, turned off location service off on reminders and hasn't come back on since.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Try clearing one app at a time from your task manager (double tap home button) and see if you can find the bad app. May require to delete and reload. Can also do this the other way. Close all apps do a reset (home and power button) and see when the arrow reappears.
If you have the " the weather channel" app I am willing to bet that is the one.
