Lock screen notifications
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
Yes, it is normal. I think it appears like that either because it's a new notification or it's the only notification or even both. I've seen it like that before, never really thought it was out of the ordinary.
It ONLY appears on your lock screen btw.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
You can turn it off, or just have the usual alerts style notification that would allow you to hit cancel.
Ffmaster1
Oct 8, 2011
133
Do you guys see it above that big notification,like notification centar,you have to slide down to see all notifications...
iphonewarrior
13,847
699
I know what you mean, but as Benny said you can change the way your notifications are displayed. The slide down bar shows up on my phone as well.
Ffmaster1
Oct 8, 2011
133
I don't wanna to change it to old way,just doesn't make sense for me!thank you!:)
gotzaiPhone
Jun 16, 2008
1,177
Tinley Park, IL
When I was running the iOS 5 beta, the first beta only displayed the notifications in the little bars, they changed it in the 2nd beta to do the more traditional notification (in black this time) for the most recent notification and then the next time you look at your lockscreen, the little bars again.
I would like for two things:
1. To turn off the big one and always have the little bars
2. Keep the notifications on the lock screen till they're cleared just like notification center... Hell, let me pull down notification center on the lockscreen. Then I get weather on the lockscreen too!
