Lockbox Data
GolfNut
Oct 15, 2007
Is there a separate file that contains the data for the Lockbox app? Would I be able to copy it off and then restore it after upgrading and JB'ing 1.1.3? I would like it if I didn't have to reenter all of my data.
Thanks.
blurm
Sep 9, 2007
46
HMMM, Can't Get Data File to Work
I recently upgraded to 1.1.1 and am using Lockbox
The reason I upgraded to 1.1.1 is I had to do a restore unfortunately and thought that this would be a good time to upgrade to a new firmware.
I ran 1.0.2 for a while, installed LockBox, added the datafile and had no problems with accessing the info on LockBox. Now when I load that data file running version 1.1.1 nothing it no longer recognizes my password.
I just powered down my phone and found that it now recognizes my old password but the password files are misssing, hmmmm.
Any Ideas?
Try looking in /var/root/Library/
blurm
Sep 9, 2007
46
You just now upgraded to 1.1.1?
I upgraded to 1.1.3 and I had to start over with a new password and new info but fortunately I backed up info on my pc.
yes, I upgraded just yesterday to 1.1.1, lazy huh? It worked when I restored the data using the data file when I was on 1.0.2 but I'm having trouble now that I am using the new firmware. yes I don't know if it's bc I used the 1.0.2 firmware to create the datafile in the first place or what.
