locked out and no code
Thomas Watts
Sep 12, 2011
My son set a lock code on our iPad 2, then changed the code, then forgot the code and over used it. Now the iPad is disabled. Someone help, PLEASE!
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
That is a sticky situation. I will tell you that most won't help with this because, no offense, sounds like it could be a stolen iPad story.
Take into Apple. They will verify it is yours and I believe they can reset your iPad.
Thomas, you just need to restore it on the computer it is synced with. You can restore from backup.
iNinja
Aug 8, 2008
3,986
20
UK
I thought this is only possible if the computer has had the device plugged in when the device was unlocked but after the code was changed? If the code was changed, and the screen was locked prior to plugging it into iTunes I think they may see the "device has passcode, unlock and try again" message?
If he knew the new passcode, he could enable it by entering the correct passcode in iTunes on the computer the phone is synced with. However, his son forgot the new passcode, so it will need to be restored. It can be restored on the computer it is synced with and the backup can be applied.
