Looking for a new case!
kackac
Jan 1, 2008
17
Hey everyone, I'm new here. Well right now I have the incase rubber case for my iPhone, and it is okay overall. It's stretched out a tad, and it tends to collect a little dust around the edges. Also, it's really a pain to take out of my pockets as it is really grippy and it turns the pocket out. So basically I'm looking for a new case that is slim and doesn't take too much away from the phone, but also has a little grip so it isn't as slck as the phone itself. I have found a couple of cases that look like they might fit what I want. Also, I'm not huge on super-protection, so I don't mind if not every part is completely covered.
First, the Cozip case.
http://www.amazon.com/apple-iphone-...2?ie=UTF8&s=electronics&qid=1199541324&sr=8-2
Seidio Innocase
http://www.seidioonline.com/index.asp?PageAction=VIEWPROD&ProdID=936
Any thoughts on these or other suggestions would be great. Thanks!
DUKEL
Jun 27, 2007
646
S.D. CA 92109
Seidio Innocase
Never seen the cozip but I started a thread about the Innocase. It should be out on the 28th.
http://forums.everythingicafe.com/threads/new-seido-innocase-for-iphone.18499/
15,384
1,089
you should check out the Agent18 case and the Switcheasy Capsule. They're both very sleek and protective. If you are sensitive to light scratches, you may want to sand-down the inside of the Agent18... it has some slight creases that some have reported scratching the back of their phones. I haven't had a problem with mine, though.
Jan 12, 2008
I use agent 18 easy to install, and easy to get out of pocket!
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I have the Switcheasy and am very happy with it. The only thing is that the screen protectors that come with it (3) are junk. I use the anti-glare from Apple.
