Looking for car mount that works with iPhone 6 Plus
azfalcon
Sep 14, 2014
61
Anyone have or recommend a good car mount for the 6 plus? I'm tired of trying to get directions or change music while driving
5,578
I've been using a combination of a Bracketron satellite radio dash mount (just the portion that attaches inside the dash) and a Bracketron Universal GPS Window Mount (just the portion that holds the iPhone) since 2009. I got both parts at Best Buy. They installed it and only charged me for one of the two. You can glance over and easily see what's on the screen.
http://www.bracketron.com/universal-gps-window-mount#.Utn3o2Tn8hQ
http://www.bracketron.com/satellite-radio-universal-dash-mounting-kit#.Utn18GTn8hQ
Here's a picture of it with my iPhone 6, but it can securely hold a large variety of sizes, including the iPhone 6 Plus.
djwindsor
Jul 7, 2009
755
44
Neponsit, NY
I have a mount that utilizes the CD player. You insert the unit right into the slot where the cd would be inserted. Works great. They make one with a magnetic holder and also one with the usual claws.
Sent using iCafe app
Feb 21, 2009
The proclip USA is a nice setup. I have that in my car. It was a little spendy, but I like it alot uses the 30 pin to lightning adapter. FWIW, I bought the adjustable one for a small case iphone 5 which is what I was using it with originally and it still fits the 6 with a small case. A little wobble if you keep it loose, but not enough that I'm concerned about it.
coop1701
Jun 30, 2007
899
114
43
I love Proclip.. I have used their mounts for years and in 2 different cars.
ednygma
Mar 9, 2009
428
86
Louisville, KY
I am another ProClip user. I have used them in all my cars for the past 8 years or so. You buy a mount specific for your car and a holder specific for your phone. As noted above, it is a little pricey but well worth the money in my book. I actually do not buy the holder for my phone but buy one of their adjustable ones. That allows me to make it work with or without a case. I am using the same one on my 6+ as I did on my 5 with no issues whatsoever. I just expanded it's grip width and voila. I use the apple leather case on my 6+ and it fits like a glove in the proclip.
http://www.proclipusa.com/
radtechy
Jul 20, 2011
505
41
I'm still using using my proclip 5S rugged case size mount which fit my life proof with a 6 using a speck candy the only thing is the thickness is too big but not bad for now until the proper stuff is made
