Looking for reliable, comfortable, easy to use Bluetooth Headset
AubreyL
Jul 10, 2007
I read a lot of reviews of Bluetooth Headsets when I purchased my iPhone. It seemed the Jawbone was the clear winner and came out far above others in reviews. I almost waited for the Apple Bluetooth Headset but I know it's not out yet and the fact it doesn't have the earpiece to go around your ear makes me wonder how well it'll stay on.
I ended up getting the Jawbone after the Apple Store spoke highly of it. I finally got it hooked up. Quality wise it's great. It seems simple to use and the sound quality is great. I only have two issues.
First, it seems kind of uncomfortable. I think with changes ear pieces and maybe bending the metal some I can finally get a feel that's comfortable for me with time.
The second is what bothers me. The noise cancellation is easy to use. I like that button but have a issue with the on/off answer/hang up button. Unfortunately it's not like the other. I feel I have to push the headset too hard. Sometimes it's hard to push it hard enough of it just presses it against my skin so hard. I read some on google and seems some others have this same issue. Is this something you get used to? Can you also answer and hang up calls on the phone itself without using the headset?
Unfortunately I may be back to researching a good headset and I'm confused. It seems like a lot just comes down to personal preference with feel but I don't want to have to buy a lot and deal with returning items, paying restocking fees, etc. The brands that seem most popular are Jabra and Plantronics but I have seen some Motorola headsets that seem nice and I think Sony makes some nice ones. I just like the noise cancellation but are there certain brands I should look at and specific models? I want something that is light but stays on well and has good quality and most of all, easy to press buttons. Any advice?
Quake97
Jul 10, 2007
522
Philly Burbs
It does come down to personal preference in the end. If you don't have a problem with it, AT&T stores let you try on the ones they have in the store. they have wipes there too so you can clean them before putting it in your ear. I go back and forth about whether I like the in ear ones or the over the ear ones. I like the smallness of the in ear, but I also don't like the fact that the speaker is so close to my eardrum. Of the bluetooth headsets I've had over the years, I like the Samsung WEP200 the best.
Joe
