Losing WEP key ?
tinmanx2
Jun 30, 2007
So... I started experiencing something weird on my iPhone. I've been losing my WEP key sporadically. That's right... I go to use the WiFi connection and all of a sudden it asks for the WEP key again; even though it was working before 5 minutes before. Is somebody else experiencing the same? I'm going nuts with this.
Thanks,
Francis
the watcher
Jul 5, 2007
183
hey, the same thing happened to me, all i did was turn the power all the way off, and that fix the problem for me, and i did'nt have to enter my password agian try it.
alb0zf1n3st
Jul 2, 2007
624
try turning power off if not then try connecting to it once your connected turn wifi off your phone completely and wait few mins and turn it back on
tinmanx2
Jun 30, 2007
Hey! Turning the unit off and back on worked. It is just a pain having to do this... To me this is obviously a bug they need to fix.
Thanks!
Francis
alb0zf1n3st
Jul 2, 2007
624
Sure no problem.. I had that issue also that seemed to work
