Mac Tips and Keystrokes
5,578
Command Delete - Moves file to trash
Command Shift Delete - Empty trash with dialog
Command Shift option Delete - Empty trash without dialog
Command a - Select all
Command Option Eject - Sleep
Control Command Eject - Quit all apps and restarts
Command 1 - View menu as icons
Command 2 - View menu as list
Command + Spacebar - Open spotlight. You can use this to open apps, type in calculations and find word definitions.
Command H - Hides open windows
Open terminal and type, say hello
Don't use any punctuation or forget to type the word say before your text.
The Mac will then say, "hello"
Click once on a file and then press the spacebar to see a preview of it.
Click on a file once and then hit enter to change the name of the file.
The Apple
3,105
Indiana
Hold command and press tab to open an icon list of open applications. Tab through to select an application, close the application by pressing Q
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Learned this one today via Lifehacker.
Option-Shift-Volume Up/Down. It will adjust your volume in smaller increments that using just volume up/down.
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
I have some to add of my own sorry if they are double posted.
Screen shot = Command+Shift+3
Spotlight Search = Command+Space
Sleep Computer = Option+Command+Eject
Move focus to dock = Control+F3
These are just some of the keystrokes I tend to use a lot and the more you use them the more you get to know more commands and its really amazing how quickly you can navigate through your Mac. There is a whole list of every command on Apple's website once I find it I'll post the link.
15,385
1,089
I thought we had a huge thread on this...
Anyway, my favorites that haven't been mentioned:
Cycle between open apps - cmd+tab
Quit current app - cmd+Q
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
Hmmmm that's a good one I will be using all the time now. I need to put that on my most favorite list.
styfle
Mar 31, 2008
3,381
Aw you beat me to it :p
Well here is a (mostly) universal shortcut:
Command + ,
opens preferences for the current application
Command + `
cycles through windows of current application (such as different finder windows, etc)
Command + Shift + 4
lets you select a portion of your screen to take a screenshot of (i use this ALL the time, just drag a box around whatever you want)
Command + t
opens a new tab in most applications
Command + w
closes tab/window in current application
Command + [0-9]
selects a specific tab in current application
Command + c = copy; Command + x = cut, Command + v = paste; Command + z = undo; Command + y = redo;
The Apple
3,105
Indiana
I don't know whether this transfers to Firefox, but when using Safari....
Cmd/+ - zoom browser screen in
Cmd/- - zoom out browser screen
Cmd/0 - reset browser screen
also
control/scroll wheel will zoom in or out of desktop.
The Apple
3,105
Indiana
I use onboard built in dictionary often. Hover over a word you want a definition for and press ctrl/cmd/D and up pops a definition box!
The Apple
3,105
Indiana
Just FYI. I had a co-worker walk into my office and I typed into terminal, "say Oh my gosh, your friend there has terrible coffee breath." My coworker looked puzzled!
5,578
It's also fun to use it in conjunction with VNC. They'll just see terminal open on its own and start talking. :)
greasemuntney
Apr 4, 2010
103
Alabama
Just noticed while reading this thread that on my Macbook Air that if you tap the DELETE button it will go back to previous page you was on.
Delete button, takes you back to previous page.
Mommy
Feb 19, 2011
1,104
88
NY
OMG!?!?! I am NOT getting a MacBook Air! I give you all credit, that is hard & weird! I think through and through I am a PC!
D
dorisqiu
Guest
Thank you. It will help us to learn more about Mac:)
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
stock-photo-series-of-sequenced-light-bulbs-at-different-brightness-levels-17155009.jpg
I know I'm replying to an old message, but thanks for sharing that. I never knew that one. I decided to try the same combination on the screen brightness controls, and it turns out it also works there.
This is working on Mavericks, folks, so those of you on the latest version of OS X can still use this!
