Mac Tutorial: How To Put DVDs on the iPhone
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
How To Put DVDs on the iPhone: A handy tutorial created by Phillip Torone at Hackszine.
HandBrake is a GPL'd multi-platform, multithreaded DVD to MPEG-4 ripper/converter - it's super easy to rip the DVDs you have and put them on the new iPhone - they look great and are about 1 GB each, here's how... First, get HandBrake - Link. There are also PC versions of HandBrake, it might work about the same way.
Install it, run it. Pop the DVD in. Pick the DVD volume. Choose your settings, I use the defaults usually.
It takes about 30 min or so, it runs fine in the background.
Drag the MP4 file it makes in to iTunes, in videos tab in iTunes for the iPhone select the movie, click Sync.
The video is in the videos section. iPod / Videos.
It looks and sounds great!
NOTE: This is intended only for personal use with your purchased DVD's and not for the commercial distribution.
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
One addendum. If you are converting TV shows, then you might want to convert each episode. Otherwise, it could get unruly to track down episodes.
joejna
Jul 17, 2007
hey chris i found these settings depending on source of movie
432 x 320 from fullscreen
480 x 272 from widescreen
now is there any way to make file smaller in size because movies are almost
a gig
thanks
HELPmepLox
Jul 15, 2007
So.Cal
awsome thanks
thats soem really useful information especially with the pic.
all these other threads bout iPhone dvd... just read read read..../..
alpha_omega
Jul 19, 2007
Okay, I'm trying Handbrake on a Windows XP. I'm having trouble under "Destination". It allows me to browse for the folder, but I can't select it. I'm not really good with computers, but if someone could help me, I'd appreciate it.
theraker007
Jun 15, 2007
322
Im on vista, im following the instructions exactly with my wedding crashers dvd.. and everytime i click encode video, the little dos thing comes up and then the message saying encoding complete comes up like 5 seconds later and nothings happened.
anyone know whats going on?
xoulo
Jul 9, 2007
323
same thing happening to me. im so frustrated
the source i click on the dvd, and it wouldn't do anything. it would just leave it blank and wont work
its like i cant choose my source of dvd, because it wouldn't work.
anyone have the same problem?
Shirazik
Jul 21, 2007
37
Irvine, CA
Yup same thing is happening to me. I dunno what the problem is either...damn
What's another program out there that can put DVD's on the iPhone that's actually decent?
Lazarus
Jun 6, 2007
380
Miami
hey i use Videora and it's great but is it possible to get a widescreen DVD to show full screen on the iPhone? and please don't say double tap the screen to zoom in because it's still widescreen view
SCMedic
Jul 7, 2007
95
What program are all you mac users using to convert already downloaded movies to iPhone?
SCMedic
Jul 7, 2007
95
I have handbrake, but it won't convert .avi files, which I already have about 30 movies, to the correct codec.. It just rips, or converts already downloaded movies..
What specific files does it do?
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
30 minutes, eh? Perhaps it takes 30 minutes on a dual-core G5 cheese grater.
On my lowly G4 QuickSilver, one can expect to loiter about for an hour and a half for a one-hour DVD file.
Is there something faster for us Mac types?
.....sT
You're pretty much stuffed I'm afraid.
There's a physical limit on how fast you can read the DVD, and then process the data.
No software is going to help with that problem :(
