Mac Virgin Needs Help
reas0n
670
20
Stamford, CT
www.ohitsjustpete.com
lol catchy title ey?
anywho i need some help i just got my first mac...loving it so far... need some help from mac owners tho i need a program that will tag my music and find the album art for it... i have i program like that for PC but its not compatible with mac anyone know where i could find such a program free preferably
Also ANY other applications you guys would recommend would be very helpful!
Thanks,
reas0n
geordisjd
2,442
"program that will tag my music and find the album art for it"?
iTunes?
kr3st
166
Winter Park / Orlando, FL
ahhh i cant think of the name of the program but its monkey something... wtf im going to google it and find it.
kr3st
166
nevermind i found it and its windows only i didn't know if they had one for mac or not. but what i do if iTunes cant find the artwork i go http://albumart.org/ and type the band name or album name in and it finds the cover/artwork and i save the image to my mac, then i select the album and right click on all of the songs that are selected and add that artwork for that album and it works perfect for me i don't mind spending time doing it... but i hope this helps.
I don't know about this program you speak of, but here's my list of must-have apps:
AppDelete
Simple: Drag the icon of the application you want to delete into AppDelete, and it gets rid of any and all files associated with the application.
http://www.apple.com/downloads/macosx/system_disk_utilities/appdelete.html
Signal
Great WebApp for iPhone/Mac that allows you to control your iTunes from the iPhone. Punch a hole in your firewall and control it from anywhere!
http://www.apple.com/webapps/entertainment/signal.html
LockDesktop
A simple app that keeps all applications running and windows open, but returns to the login screen.
http://www.apple.com/downloads/macosx/automator/lockdesktop.html
Candy Bar
Application that allows you to change the icons of anything on your Mac. (This could help those of you not buying Leopard make Tiger look like Leopard.)
http://www.panic.com/candybar/
Quicksilver
Launcher on steroids.
http://quicksilver.blacktree.com/
reas0n
670
20
Stamford, CT
AppDelete
Signal
LockDesktop
Candy Bar
Quicksilver
thanks for that list MacMan...quicksilver and deleteapp are a god send right now...don't think im gunna use signal too much no andy bar as my leopard is coming soon lol and im gunna test out LockDesktop too
also im experimenting with the Adium Instant Messenger Client or do you know of a better one?
and keep the lists coming i need all the help i can get right now...got a $3,395 machine and i know im not using it to its full potential
