MacBook battery.
hmfc-1874
Sep 10, 2011
510
34
My MacBook Pro is new (bought about 3-4 months ago)
And touchwood the battery keeps working as well as it does, but like say a few years I see it starts to turn poor, can I take it to Apple shop and get battery replaced and how much do they roughly cost ?
Cheers
Sent using iCafe app
Dec 15, 2008
5,386
340
27
Pensacola, FL
http://www.apple.com/support/products/mac.html
"Every Mac and Apple display comes with a one-year limited warranty and up to 90 days ofcomplimentary telephone technical support. Extend your coverage to three years from your hardware product’s original purchase date with the AppleCare Protection Plan. You get direct, one-stop access to Apple’s award-winning telephone technical support for questions about Apple hardware, OS X, and Apple applications such as iLife and iWork. And you get global repair coverage for your Mac and Apple display through convenient service options."
Did you get an extended warranty or just the standard one year warranty?
Dec 15, 2008
5,386
340
27
Pensacola, FL
I may possibly be in this situation now. My laptop was fully charged this morning. I rebooted it and it turned off. I turned it back on and 45 minutes later it turned off and now it's completely dead. My Apple guy went through several technical steps to get the MacBook Pro back on. They didn't work. Also the charger is flickering orange now. He said if The Computer Store quotes me more than $300 then to stick with Apple. Maybe it's only an issue with the charger. I'm hoping to find someone tonight with an Apple laptop charger that I can try to use.
Late update, but it was only the battery needing to be reset.
