MacBook or MacBook Pro
fedexgnd
Aug 7, 2007
142
Hey all. Well I have finally made up my mind to make the switch from PC to Mac. I was looking at the Black Macbook. However, i also like the Macbook Pro. Can i get some useful input on which one I should go with.
Thanks in advance
Sleeper
Jul 21, 2007
256
Depends what you need it for.
Details?
fedexgnd
Aug 7, 2007
142
finance stuff with quicken (i will have to get use to it, i am used to Microsoft Money) iTunes stuff with iPhone. nothing too major, Maybe dable with making movies or websites.
It depends.
The MacBook is a more compact, lightweight computer. In my opinion, it's better designed than the MacBookPro.
The MacBookPro is exactly what it says it is: The MacBook, but Pro style. It can handle more, and is better if you're going to use it for work, etc.
They both have the same hardware and software features. The Pro is also, of course, a bit more expensive. I have the Pro and I love it.
Or do what I did, go for the one you like the best. I chose the MacBook Pro. I didn't like the plastic white pr black casses. Sure I just use it for internet and syncing with my iPhone and iPod but I have a great looking computer to do it with!
reas0n
670
20
Stamford, CT
www.ohitsjustpete.com
i also went with the MacBookPro... but im a graphic designer so i needed it for work on the go...i used my girlfriends MacBook with adobe and it only really worked well when plugged in...and the MacBookPro works freaking AWESOME on the move...also you gotta think if you want to edit/create movies the bigger screen will also be good for you...just my opinion
scandalex
Sep 16, 2007
771
I've been weighing this decision as well. I've decided my present to myself will be the MacBook. I think the Pro for me, would be overkill. And I like just how small the MacBook is.
Now I just need to decide; black or white?
Decisions.....decisions!
Sleeper
Jul 21, 2007
256
Yeah, go with the Macbook. Buying an overpowered unit is just crazy if you're not going to use it.
Macbooks are generally superior to the current generation of Windows based notebooks - especially the ones with Vista (ugh) - so it'll serve you well for a good while.
Oh and get a black one - the white ones can get a bit scabby after a while.
deac
Jun 29, 2007
371
Anyone seen any more information on the rumors a month or so ago that the MacBook line was going to the brushed aluminum look of the rest of the line? The story seemed to be only a matter of when.
I too am in the decision quandry -- last time I was in an Apple store, I saw that the Pro was only a couple of hundred dollars more than the MacBook, the way I would get it configured so seemed to be a no brainer with the larger screen size. But now remain torn between the glossy vs matte monitor. I both do graphic design and go to press with 4 color work but also like the vivid appearance of personal pics and videos.......
termleech
Sep 7, 2007
1,154
McPherson, KS
Personally I have a MBP and I love it. I got it for two reasons
1. The better video card. If you are ever going to do video editing or gaming, then you want the better card. Plus it doesn't tax your system by having to use shared memory. Overall much faster and nicer.
2. The screen size. The resolution on the MB just doesn't do it for me. I'm a huge multitasker and always have a ton of windows open. With the MBP I can see a few windows at once and not have to hid them. I would be doing a lot more switching on the MB. Plus being a programmar, you always want the most real estate you can get. I only wish the 15.4 MBP were 1680 and I would get a new one.
BTW, mine is one of the original MBP. I bought it two weeks after the announcement and I'm still using it. I've upgraded the RAM and the hard drive, but it still runs like a champ. And I'm still getting great battery life (about 3 hours of normal use).
deac
Jun 29, 2007
371
3 hours is great? Wow, I haven't really been paying attention to battery life reports. Thought it was more like 5-6 hrs.
termleech
Sep 7, 2007
1,154
McPherson, KS
5-6 hours on a laptop that's not a subcompact. Whatever you are smoking please pass some over this way. The only laptops you get over 3 hours on is the subcompacts which IMHO aren't worth doing any real work on for any extended period of time. They are usually too cramped.
methcat
Sep 5, 2007
25
MBP!
i just switched from a PC to a macbook pro and I loveee it! I don't do "pro" things with it but I liked the bigger screen haha, it's a 15 inch because I thought 17 would be too big. yayayay.
When I first brought my MacBook Pro home, I tested the battery life. Just normal surfing, I had an optical mouse attached and my Novatel Sprint Broadband Card attached. I got 4 hours and 10 minutes. I also had the brightness all the way up. I was amazed at this. I have two other laptops, both HP. One is a 3GHZ 17" and it barely gets over an hour and the other a 2.0 Dual Core 15" with barely 2 hours. MacBook Pro FTW!
Not if you want the bigger screen. I can't see using a MacBook with such a small screen. The bigger screen on the MBP plus the aluminum case helped make my decision. The lighted keyboard also helped although I will probably never have a use for that, it's just cool to have.
May 6, 2007
995
United States
It depends.
Your statements on size, not to be rude, are false. It is true that the MacBook is lighter, by 0.4 pounds, but it is in fact a thinner computer, by 0.08 inches. While this is an insignificant amount in most cases, I just want to point out that the MacBook Pro is not at all a fat or clunky computer. I would agree that the MacBook is more compact in the sense of height and width, though. The MacBook Pro simply has a great design and has, in fact, a better performance to size ratio than that of the MacBook, in my opinion.
Both are simply great machines. They will both run well and meet your needs, which seem to be pretty simple. Whether or not you have already made your choice, and I presume you have, I would like to point out also that the MacBook works great for anyone browsing the internet, creating word documents, creating Excel or Powerpoint files, or using simple graphical programs or using any of the iLife or iWork apps. This is where the line is drawn. Using more complex programs, such as Final Cut or Photoshop, is simply more efficiently done on a MacBook Pro. It is as the names suggest, the Pros are simply for the person who specializes, or is a "Pro" at something and is thereforee using more complicated applications pertaining to that specific subject.
There is also the matter of cost. The margin between the cost of the Black MacBook and that of the lowest MacBook Pro is around $500, or a third of the Black MacBook's cost. That means you are paying a 33.3% premium to have a processor that is the same speed. So, where is the true difference found? In the graphical side of the machine. The screens are nice on all Apples these days, but the MacBook Pro runs on a better native resolution (1440x900) than that of the MacBook (1280x800) and the upward resolutions of the MacBook Pro are more complex than those found in the MacBook. Also, the screen size is a minimum of 2 inches bigger, so everything will be on a bigger scale, while still keeping the picture just as sharp.
The other, major bonuses of the MacBook Pro are found in the Hard Drive capacity and the GPU (Graphics Processor Unit). The hard drive on a regular MacBook starts at 120GB, sufficient certainly for the simple tasks mentioned above. If you are an avid music listener, a future director, or even just a person who uses many applications, this simply is not enough capacity. The MacBook Pro starts at 200GB of capacity, and this is definitely a large enough amount of memory to keep people running for years. The GPU on the MacBook shares memory with the main memory, basically meaning that only a small portion of performance is alloted to it at once. This simply means that graphical applications or games will not look nearly as good on the MacBook Pro, which has a separate and high-quality Nvidia Geforce 8600M chip.
Other benefits of the Macbook Pro include better sound quality, a battery life bonus of half an hour (in theory) and a better sellback value when the time comes to sell it.
Both systems are very good, and this is my limited knowledge on the issue. This debate could go on for hours, but simply put, if you are a user of basic applications, or you are a bit squeamish about spending extra money, go for one of the MacBooks. They are sophisticated and well-made machines. Anything beyond that, or if you have a little extra cash to shell out, buy a MacBook Pro.
Good luck to all!
scandalex
Sep 16, 2007
771
Both systems are very good, and this is my limited knowledge on the issue. This debate could go on for hours, but simply put, if you are a user of basic applications or are a bit low on cash, go for one of the MacBooks. They are sophisticated and well-made machines. Anything beyond that, or if you have a little extra cash to shell out, buy a MacBook Pro.
Good luck to all!
You gave reasons why one should go for the MacBook- how about simply just wanting one? Granted, we all have different needs, but your "low on cash" remark that made me say WOW! It's like anyone that chooses the MacBook is too poor to afford anything else.
15,385
1,089
if i was low on cash, I wouldn't be buying a mac of any kind.
May 6, 2007
995
United States
Sorry if this statement came out wrong. What I meant to say is that if one does not wish to spend an extra portion of money, then they would likely opt for a MacBook. I said nothing about being poor, and I an sorry if my post can be desensitized to appear in that fashion. As shown I highly respect both machines and the buying of both, so I will edit my post. Thanks for pointing out this gap between meaning and general perception.
15,385
1,089
yeah... i should probably use these -> :) more often.
