MacBook Pro MacBook Pro and creo 2011?
rom x
Jan 18, 2011
1,048
99
helping a friend get a new laptop for school. and i wanna make sure it will run creo 2011. is anyone running this on their macbook?
rom x
Jan 18, 2011
1,048
99
did some searching but still could not find a solid yes or no answer. guess no one here does any cad modeling on macs.:(
15,385
1,023
It should be a pretty cut-and-dry answer. Either Macs are supported or they aren't...
The software developer can't tell you?
primsa
Dec 12, 2007
235
Rockford Il.
The only cad program I have seen for mac is is autocad. I use SolidWorks on my mbp however I use boot camp and run it under windows 7.
noit
Sep 21, 2010
25
Northampton, PA
Creo aka pro/e does not run on Mac osx. Neither does Solidworks. As far as AutoDesk, only the 2D CAD package AutoCAD has a Mac version, Inventor does not. Boot Camp may work but i haven't tried it so I can't comment on performance.
rom x
Jan 18, 2011
1,048
99
yes i kinda knew it wouldn't. so i ended up getting an ibm t410 and it runs great. but thank's everyone for your replys
