MacBook Pro MacBook pro heats
bikerboy
Jun 20, 2009
263
Ohio, USA
My macbook pro heats up a lot , at the area right under the screen , it's even hard to keep your hand in contact with that area for too long because of heat, is this normal ?
any suggestion what to do to fix it ?
Angela16
Aug 22, 2012
Do you have it on charge whilst using it? Reason am asking is that my friend used hers whilst constantly on charge and it literally buckled with overheating
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
In my experience, it only heats up when I'm using CPU/GPU intensive applications. Take HandBreak for instance, it's a guarantee that my mid 2012 MBP would heat up when I'm converting a file.
3D games would also make your MBP run hotter, even Gameloft's Order & Chaos does it.
bikerboy
Jun 20, 2009
263
Ohio, USA
I don't know what is wrong with my mac exactly , it gets really hot , it blistered a table , took it to a genius and they couldn't find anything else, asked me to screen temp reading , it reads around 85-92 which supposedly normal , but the black thing under than screen gets really hot , u can't hold your fingers on it for too long
