Macbook Pro Help
KPSK
Jun 13, 2007
123
I have a Macbook Pro that i would like to transfer information from it to another Macbook Pro. Problem is that one of the Macbooks screen will not come on but it seems to be running since the light by where you open it comes on. Is this possible and how would o go about doing this? Thanks in advance.
28,365
5,507
Do you have a monitor you can connect to the MacBook with a broken screen?
KPSK
Jun 13, 2007
123
No but i could probably borrow one.
KPSK
Jun 13, 2007
123
Can you pick what you want to move? I just want like pictures and maybe some programs and not the whole thing. Does both of them have to have the same operating system to do this? One is 8 years old that the screen does not work and the other is 2 years old with the latest os.
