Macman on Cydia
blazew0n
Aug 19, 2008
121
I've installed this program 3 times and it does not show up. I know with other apps, you can go to uninstall the app after dl it. The option is not there so i'm assuming it's not installing at all. This a common problem with the game?
Saverino
Jun 1, 2008
4,480
92
Burbank
Not for me. I installed it no without problems.
daddyd302
Jul 13, 2008
108
If you don't see any files on the phone and the progress bar moving, then no it's not installed. You need to keep doing it til it does. I had to do it 3 times before it downloaded and installed itself on mine this morning.
blazew0n
Aug 19, 2008
121
^^ you were right, thanks for the help :)
