Mail Attachments
Cubvenam
Jul 23, 2010
I have mail and an attachment in a message but all i have is a paperclip. I cant find the attachment in the email. Is there any setting i ca. Chhange? Or is there a solution?
Cubvenam
Jul 23, 2010
It is a pdf i can open it in the actual client on my computer, which is a pdf
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
Does the person that sent the email have a background on it or a small pic. If they do that will be the paperclip you are seeing.
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
The OP is taking about an actual PDF attachment... iPhone readable attachments are usually found at the end of the email.
Cubvenam
Jul 23, 2010
Yeah it is not there i checke i can open the attachment fine on my client, firstclass client, but on my iPhone it doesn't work
mark00st
Jan 28, 2011
I used to be able to open email attachments now not able to. .PDF, .xls & .doc not working? Please help as I have already done a restore and that didn't help.
budala15
Nov 17, 2013
150
Why doesn't mail allow me to add an attachment when starting a new email or replying to one?
28,365
5,506
You can attach photos and videos by pressing and holding, tapping the arrow on the right and then selecting Insert Photo or Video. Use DropBox if you want to attach other types of files to email.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
Glad to know cause I had no clue you can attach by just holding and tapping. Learned something new ;)
iphonewarrior
13,847
701
You can upload pictures to Mobile Safari (and other compatible browsers)as well i.e a photograph to this forum. Try it :)
Ledsteplin
Oct 29, 2013
4,819
985
65
Florence, AL
That's an feature I had not noticed. Will come in handy. Thanks!
James1970
Sep 27, 2010
Canada
communicationspro.ca
Just a quick question, why does Apple not allow the attachment of files in their emails. I mean you have to use third party software to do this but why do they not build it into mail and allocate a space for storing files that you can attach at your finger print without resorting to other software to do this?
28,365
5,506
Possibly because it would rely on browsing a file system that they currently have locked down. Eventually they may add a folder for dragging and dropping files, but using DropBox to handle this for now is convenient and very easy.
James1970
Sep 27, 2010
Canada
Thanks a million for your reply but it seems weird that they have all these options on a phone and disable such a feature. Perhaps it is to safeguard the device from threats but then again these third party software have their own allocated work space to store files like for example Documents by Readdle. Thanks a million again for your reply.
