Mail Recycle Bin Flaw
kakofonix
Oct 2, 2007
596
I hope Apple will reposition the iPhone mail recycle bin in the next update. Right now, it's positioned directly above the Home button and I've frequently fat-fingered it when I meant to use the Home button, inadvertently sending the open mail to trash. What's even worse is there's a bug with the recycle bin that doesn't move mail back into the inbox...the mail just disappears when you try to!:mad:
gcvt
Jun 21, 2007
1,029
San Francisco
Probably not exactly the solution you're looking for but if you go into Settings>Mail you can turn "Ask Before Deleting" on. This will pop up a confirmation button before it moves the mail to the Trash.
kakofonix
Oct 2, 2007
596
I'll use it until they fix the bug...thanks!
