Mail signature iPhone
May 1, 2011
Hi, I need to set up a different signature for each of my three email accounts. Is it possible on the iPhone? I can't find a way to do it.
RoofMonkey
Jun 21, 2010
8,858
2,047
Like Benny said, no option on the iPhone to do that. Most providers offer a signature option for each email address. Who are you using for mail?
May 1, 2011
I have two mail accounts set up on my Mac. Exchange and Gmail (both through Mail from Mac). in Mail I can switch between many created signatures, but in the iPhone there is only one choice. Too bad :(
Hi,
Natively speaking, iOS does not provide separate signatures for different mail accounts. The standard is 'Sent From my iPhone' which is changed in SETTINGS >> MAIL, CONTACTS, CALENDARS but this is a global change as you know which applies to all accounts.
If your device is Jailbroken then you can use MailEnhancer which is a tweak from Cydia which allows an HTML enhanced signature to be applied to each account.
offroadhunter
Apr 1, 2009
682
22
New York
Hi,
+1 on MailEnhancer.. I just had this same exact conversation with a friend.. he was adamant you could have multiple sigs with stock ios but has discovered that's not the case. I'll convert another to JB soon!
I think with the introduction of iOS 5 it may be the case, but at present its a negative.
SIGnify in Cydia is also an option but I believe it has far less features than MailEnhancer
