Major iPhone 3G S problems
How many Iphone problems do you have?
  • I have service carrier problems
    Votes: 9 60.0%
  • I have Apple software problems
    Votes: 2 13.3%
  • I have a combination of both
    Votes: 3 20.0%
  • I have installed apps problems
    Votes: 5 33.3%
  • Total voters
  • Poll closed .
HDRide
Jul 26, 2009
I'm having nothing but problems with my iPhone :(, first I bought an 8GB standard iPhone 3G thah had a problem with calls going right to voicemail. AT&T tried calling me and it went there so the phone was replaced by Apple with a 16GB 3G S. I thought ok now my problems are over, far from the truth. I'm having more problems now than I did with the old one. I have the same issue and more. I found the phone will connect to a 3G tower and have 4 bars of signal then while at the same spot switch to a none 3G tower and the signal will die to 1 or 2 bars. AT&T says this is normal.....okay what don't I understand here. Then I'm sitting here at my computer and the wireless is "connected" and I can even get to the App Store. Maybe it's the area I live in, I know where I live 3G isn't available but where I work is on the border of coverage.
This represents some of the problems I'm having, I'm wondering if there are others out there with the same issues?
Quake97
Jul 10, 2007
522
Philly Burbs
You don't say where you are. There are many things that can affect coverage, signal, data speeds, etc. If this is still happening with a brand new phone, then I suspect its AT&T where you live. If your phone keeps jumping back and forth from EDGE to 3G and barely holds a 3G signal, you might benefit from turning off 3G until coverage there gets better.
Joe
HDRide
Jul 26, 2009
Joe
I understand that signal, data speeds, etc. will affect my phone. What I fail to understand is why i'm having issues like calls going right to voicemail when I have a good Edge signal. Apple says turning off 3G is not a something I should have to do. I'm on the phone with them as I write this. 3G is not available here where I live so "jumping" isn't an answer to my issues.
ipwn3gs
Jul 12, 2009
155
Att 3g drops to edge or sudden connection failure is common. Ever since 3g was added couple years back every phone gave me those problems now and than. The sudden drop in bars i have with my iPhone on hourly basis.
Doing a quick air plane mode n being near window always helps tho .
Those are why Apple will soon switch thd iPhones to new career . att just cant handle it specially in big cities like d.c. And la
ZipZap
Dec 15, 2007
529
OS3 is not ready for prime time...I feel like I am testing this for Apple. And paying big buck to do so...Anyone know if I can take a 3GS back to 2.2?
Tinman
4,334
183
Aridzona
IMO a poll that assumes all are having problems is worthless. Since I am not having problems, I cannot accurately vote. Needs to have a "no problems" option to be remotely valid.
Mike
Quake97
Jul 10, 2007
522
Philly Burbs
The 3GS came with 3.0, so you cannot go back to 2.2.
Joe
Quake97
Jul 10, 2007
522
Philly Burbs
I missed the part saying you didn't have 3G. As for calls going to voicemail when you're on EDGE, that's very possible. EDGE does not allow for simultaneous voice and data. When you're iPhone is in an "active" data session calls will go to voicemail. An "active" data session is when you're streaming audio/video, downloading an email, bringing up a webpage, etc.
Joe
KevJD
Aug 30, 2008
168
+1 :sneaky:
Jeffois
Jun 5, 2008
120
Call me lucky, no probs with mine. :cool:
5,576
No problems here either. Great battery life and full strength 3G.
greenjbhsd
Jul 13, 2007
571
You did not put a poll selection for "no problems". So far the 3Gs has been rock solid. My cellular performance has been vastly superior to how it was with the original iPhone and the 3G service here in Salt Lake City is very nice and peppy. Overall I am extremely pleased.
