Major Myspace Problem
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Im sure most everyone else on here has a myspace page and im wondering if ya'll are having the same issue i am.
I have yet to be able to log on to my myspace and i bought the phone when it came out at 6pm. when i enter my email and password it takes me directly back to the main myspace page and prompts me to enter the info in again. I have tried going to my page directly and trying to send a comment and having it force me to log in to do that but still no luck
andyone know how to correct this problem?
I have one hard and soft reset of phone 2x, enabled and idsaled wifi even though im on edge.
any help would be greatly appreciated as i cant check my page and its super annoying as im sure you can imagine.
thanks in advance fellow iPhoners!
Matt-
Las Vegas
grydlock
Jun 23, 2007
19
during my playing with it at the Apple store, i could never even get onto the myspace page.
should be 1 week and counting until i get my own iPhone though!
UhhhFresh
Jul 7, 2007
37
i don't know what the problem is. I log into myspace all the time.
the only thing I can say is.. Make sure you aren't accidentally hitting the <| (back) button.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Weird. Has anyone else had these troubles or am i the lucky one? who slept out on an inflatable mattress in front of att for 24 hours and got the dud of the bunch?
DD0
Jun 21, 2007
183
Myspace is a terrible website, even IE on a regular computer struggles to open it sometimes. It's probably all of the flash and random crap it has to load causing problems and not allowing it to load.
Who knows though, could be anything.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Well thats not good! lol. I have like 30 billion messages to reply too ha ha. Im gonna try to do another reset or something. Keep the advice coming, and if you are able to get on your myspace let me know that too
thanks all!
J-Sauce
Jul 5, 2007
142
Make sure youre entering your pw correct through the on-screen keyboard. If your pw has and special characters, they could be going through wrong without you even noticing. Try changing your pw to something simple in all lower case letters just as a test.
gentlegiantcraig
Jun 17, 2007
118
Sunny South Florida
I believe Apple fire-walled Myspace. I guess they didn't want kids coming into there stores just to use myspace on there displays. Just from what i have experienced.
Draven
Jun 5, 2007
Also, when you're done entering in your information, don't use the Go button on the keyboard, instead use the actual Log In button on the MySpace page.
I remember when I first got my iPhone that when trying to log into MySpace, the keyboard Go button wouldn't work to actually log in.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
I have no problems logging on.
Ok I did a hard reset two times by holding the lock button on the top of the phone and the circle button at bottom, then cleared my history, cache, and cookies and it works fine. Thanks all for your help!
These iPhone forums really do help and if we stick together and keep helping each other with our issues, it will make our iPhone experiences so much better!
Thanks again fellow iPhoners!
Matt-
Las Vegas
tamakin
Jun 30, 2007
404
Myspace is full of spyware and all kinds of bad stuff. I only go on myspace on my PC.. my PC is sluggish now and I think myspace had a lot to do with it. I have a powerbook 12" but I never go on myspace with my mac. And I never will with my iPhone!
In2Deep
Jul 4, 2007
37
I checked mine too, just can't get it to go through the login screen.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Myspace is full of spyware and all kinds of bad stuff. I only go on myspace on my PC.. my PC is sluggish now and I think myspace had a lot to do with it. I have a powerbook 12" but I never go on myspace with my mac. And I never will with my iPhone![/QUOT
My computer was slow too and I thought it was myspace too but it turned out to be all the porn LOL!
J-Sauce
Jul 5, 2007
142
Yeah dude...thats what gets you...the porn.
