Make Changes to Autocorrect
Danicks
Oct 5, 2011
I want to know how to get into my autocorrect database and just make a few changes. Example I am continually typing te and I want it to change to the. Any info is appreciates. Thanks!
15,385
1,023
In that case, you can upgrade to iOS 5 as long as you have a 3GS or iPhone 4. You will probably also have to update to the latest iTunes first.
first go here: http://www.apple.com/itunes/download/ and install iTunes 10.5.
then plug in your iPhone, click on it in the left column, and click "update" in the summary tab.
verwon
Jul 29, 2011
1,015
121
Seattle
or you could just reset the keyboard dictionary by settings > general > reset > reset keyboard dictionary
That just resets the entire dictionary, it doesn't make the changes the OP was asking about.
Sent from my iOS ecosystem!
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Sent from my iOS echosystem!
It will help. If the op has typed te a thousand times the phone has learned and thinks it is a word and the intended word. Resetting the dictionary will start you back at zero and the te will be corrected to the.
