Make Mp3 Your Ringtones
tpain
Oct 9, 2007
39
Dose anybody know if u can make mp3s your ringtones or do u have to do somthing to them like convert them and use iTunes to put them on, im new to the iPhone just got one if somebody can help thanks.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
depends.. if you have the latest iTunes then you can only make the music that you buy off iTunes into ring tones... they have to be the ones that iTunes says it is ok for you to do that... there is a little bell next to the song
fbcbeer
Oct 9, 2007
How can you make your own ringtones?
I bought iPhoneringtonemaker, but I cant find the ringtones once I look on my phone. Whats the best way?
dealers
Oct 18, 2007
ibrickr
If you are using PC, try ibrickr, it will upload ringtones for you.
420greg
Jun 26, 2007
845
Orlando, Florida
If you have the send song app you can use it to send a song already on your iPhone to 'ringtones'.
patrick_83
Oct 11, 2007
310
Illinois
I used WinSCP earlier and just drag and dropped an mp3 into the ringtones folder, but this method with WinSCP im guessing will only work with windows.
patrick_83
Oct 11, 2007
310
Illinois
I did use iPhoneringtonemaker once as a trial today and the ringtone didn't stay on my phone. BUT, the one i put in manually via WinSCP is still there.
kingofthechi
Oct 15, 2007
30
Can you post how you did it? How do you log into WINSCP?
patrick_83
Oct 11, 2007
310
Illinois
can u post how u did it? and how do u log into WINSCP?
You have to have openSSH installed on the phone, a WiFI connection, and for WinSCP you need windows but there is also a program for Mac.
But fist you have to find your phones IP which you can get in the WiFI menu under settings. Then you open WinSCP or mac equivalent, then you but the IP address where it says host name, leave the port as 22, user name is root PW is dottie, where it says file protocol select SCP, then hit login.
Now you have access to the directories in your iPhone.
I found the ringtones at var/root/Library/Ringtones.
Hope that helps you out a little
