Makin' a dock!
mittenman
Jul 25, 2007
813
Nowhere, Mitten
My poor dock! (after I tried to make it work for the new Seidio case I just got). I don't' really use it because I don't really like messing with removing my case all the time. I used to have an Incase rubber case and liked it, just received my new Seidio and really like it so far (wish it had a little more grip though). I've got a mill at work and thought I could machine it to fit, I thought the plastic was much thicker. Not the case, it's heavy cause it's got a large chunk of zinc in it. Anyway, managed to get it apart and it still works, so...............
I'm making an aluminum dock! Still in very early stages, (just started actually) and don't know how well it'll work (if at all?). I can only mess with it when I'm slow or at lunch, so it might take some time to get it right (got lots of aluminum). It should work with most cases I think, fits my Incase and Seidio fine. I'll post more pics as I go.
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Dang that does look pretty sweet so far.
Doesn't look so sweet now. Milled too far and put a hole into the slot part, oops. Need some different bits for the mill, don't have any right now that are round to make the proper shape in the bottom of the slot (like the original one). Gonna get goin' on it again soon though!
Dec 23, 2007
82
Chicago
www.novembersdoom.com
Wow, you dug this up! Unfortunately, I haven't gotten around to messing with it lately. I screwed up the first one pretty good and have been busy with the holidays and got engaged also. If I get something going again I'll keep everyone in the know.
I'm new to the forums here, so I've been going through a lot of old posts, and this project is very cool! I hope you find the time to work on it again!
