Managing photos on multiple devices
silvermoon
Jul 17, 2013
1,624
179
Washington
I really need to find a solution to this issue ASAP. The issue is that I when I get home from work, I like to get on my MBP and upload my photos for my report. This usually involves me going into the Photos app. I have to select the photo, click on Photo Sharing, and send it to the album but when I go back to my laptop, there is no photo. So as an alternative, I try to send the photo as a text to my laptop. Again, the photo does not arrive on my other device. At this point, I'm frustrated because it is taking longer than I expected to submit my photo(s). After I exhausted what I believe to be all options, I open up iPhoto on my laptop to find that after about 5-10 minutes, the photo is sitting there. What is iCloud Drive? Does this give me a way to share my photos through all the devices without me having to manually send them across the iCloud? Should I consider using DropBox? What about adjusting settings on iCloud? I need the most effective solution to keep my photo(s) synced through both my laptop and phone.
iphonewarrior
13,847
701
More information on iCloud Drive can be found here. I perform a very similar task to what you do as well, I send photographs for reporting purposes. I take the photographs on my phone (iPhone 6) or my work phone (Sam Galaxy S4), then I upload them to either Google Drive or Dropbox (usually Drive) and once they're in the cloud I delete them from my devices camera roll. Then once in I open up the laptop and within a few seconds Dropbox or Google Drive has sync'd and I attach my photo's as necessary.
iPhoto is an easier option, though. All your photo's will eventually sync automatically to the app on your Apple computers. I may have had a bad experience with iPhoto but I've always found it to be quite leggy, it may have improved in recent OS drops (haven't used it in an age).
The reason I use cloud storage away from Apple is because of the work aspect, I don't want my personal stuff full of boring work pictures :p
28,365
5,506
Enable My Photo Stream on the phone and the Mac. The photos will automatically transfer from your photo to your Mac when you're on WiFi. This won't require any action on your part. They'll just show up in iPhoto.
silvermoon
Jul 17, 2013
1,624
179
Washington
The problem is that there is a delay between the transfer of the iPhone to the MBP. I've waited up to 10 minutes for the photos to show up in iPhoto.
28,365
5,506
Nothing happens when I swipe up and tap on Airdrop.
What year is your MBP? It has to be a 2012 or later to work with iOS AirDrop. Mac-to-Mac AirDrop works fine on the older Macs.
Open AirDrop on your MBP. Now go to your phone and open the Photos app. Select one or more photos/videos. The AirDrop symbol will change from this:
to this:
when it detects your Mac. Tap it to send the photos.
silvermoon
Jul 17, 2013
1,624
179
Washington
to this:
That is a Mac to Mac transfer. I want to go from iPhone to Mac. I don't believe this functionality exists. Not in Airdrop
28,365
5,506
Yes, it does exist. I don't think you read my post with directions closely enough. I just explained how to go from your phone to your Mac. Since you have a 2013 MBP, it will work. Don't swipe up with Control Center and try to do it there. Check my screenshots and last post for directions.
